[PROJ] Anybody from Thailand?
Greg Troxel
gdt at lexort.com
Tue Jan 7 04:38:31 PST 2025
Javier Jimenez Shaw via PROJ <proj at lists.osgeo.org> writes:
> Could anybody explain why a vertical coordinate reference system is needed
> to properly use a geoid model?
(This is all a little fuzzy, and I hope that fuzz doesn't matter.)
Restating what I think is agreed: A geoid model is some combination of
numbers and formulas, that when given a lat/lon, tells you the
difference between HAE in some datum and some kind of height.
A gravimetric geoid model relates the zero of equipotential surface to
zero HAE.
A hybrid geoid model relates the zero of an orthometric datum (that is
probably not an equipotential surface), such as NAVD 88, to zero HAE. A
hybrid geoid model does not make sense without a vertical CRS.
A pure gravimetric geoid model needs only a W_0 (U_0), and we don't tend
to label that as a CRS. I would expect you'd need to complete the CRS
by talking about dynamic vs orthometric height, and you'd need dynamic
to not make a semantic mess where you can go up 100m, sideways along an
equipotential, down 100m and back, and not end up where you started.
https://www.ngs.noaa.gov/GEOID/
NGS says their gravimetric geoids:
Converts heights from ITRFxx to the NGS geoid supprface
(not NAVD 88 or other Vertical datums)
An example is "EGM2008" which I see as a gravimetric geoid model,
converting WGS84 HAE to "WGS84 Orthometric Height".
https://spatialreference.org/ref/epsg/3855/
So, if the Thai geoid is basically functionally like EGM2008, but
restricted to Thailand and more accurate, then I can see that they don't
feel the need to name/publish a vertical CRS. It would just be a
locally-more-accurate transformation.
So the question is what TGM2017 is defined to be, both the geodetic
datum for the HAE input, and the output vertical.
When you say "why a vertical CRS is needed", do you count "meters above
the W_0 surface" as a CRS? If so, is this EPGS:3855?
Separately, the idea that Thailand has no national vertical datum,
especially from before GNSS, is hard to believe. There could be a
regional datum for a few countries that is in EPSG but I'd expect your
search tool to turn that up.
More information about the PROJ
