[PROJ] proj grid not found
    Javier Jimenez Shaw
    j1 at jimenezshaw.com
    Sat Jan 11 09:02:13 PST 2025
Your file is projected (EPSG:5515) Is that working?
Looking at the documentation, it works only with geodetic coordinates
https://proj.org/en/stable/operations/transformations/hgridshift.html
Be careful, the axis order of the projection is southing-westing, to make
everything "easier".
https://spatialreference.org/ref/epsg/5515/
On Fri, 10 Jan 2025 at 22:06, Miroslav Pikl via PROJ <proj at lists.osgeo.org>
wrote:
> Hello,
> I need to prepare a grid file to transform some airborne data.
> I tried to follow description
> https://proj.org/en/stable/specifications/geodetictiffgrids.html#geodetictiffgrids
> and validated the grid with tool from
> https://github.com/OSGeo/PROJ-data/tree/master
> The grid file is placed in /usr/share/proj directory.
> But when I try to test the horizontal gridshift I get following error
> echo 5601804.80015816 6155138.44865926 291.032677173227 | cct -z0 -t0
> > +proj=hgridshift +grids=cz_jtsk.tif
> > proj_create: Error 1029 (File not found or invalid): hgridshift: could
> > not find required grid(s).
> > cct: Bad transformation arguments - (File not found or invalid)
> >      'cct -h' for help
> Other grid file from the same directory can be recognized.
> Is it possible to indicate why the grid is not recognized?
> The grid file is accessible from
> cz_jtsk.tif
> <https://uvgz-my.sharepoint.com/:i:/g/personal/pikl_m_czechglobe_cz/EWbKrKo-qRpOqBVPL8_1a1kBJKEnOQozCGyqpuPGYXos8Q?e=E2sd0j>
> Thank you very much.
> Miroslav
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250111/72526661/attachment.htm>
More information about the PROJ
