[PROJ] Extracting WKT string
Roger Oberholtzer
roger.oberholtzer at gmail.com
Fri Jan 31 05:01:29 PST 2025
Here is a snippet of code I use in C. Hope that helps tinfo->CRS_TO is
just a string like "EPSG:12345". The opts/lopts bit is the trick.
int GetWktFromProj(WGS84Info *tinfo) {
char *prj;
PJ *tmp = proj_create(0, tinfo->CRS_TO);
const char *opts[2] = {"MULTILINE=NO", 0};
const char *lopts[3] = {"MULTILINE=NO",
"ALLOW_ELLIPSOIDAL_HEIGHT_AS_VERTICAL_CRS=YES", 0};
// printf("%s: %s\n", __FUNCTION__, tinfo->CRS_TO);
prj = (char *) proj_as_wkt(0, tmp, PJ_WKT2_2015, opts);
if (!prj) prj = (char *) proj_context_errno_string(0,
proj_context_errno(0));
tinfo->WKT[WKT2_2015] = strdup(prj);
// printf("WKT2_2015: %s\n", tinfo->WKT[WKT2_2015]);
prj = (char *) proj_as_wkt(0, tmp, PJ_WKT2_2019, opts);
tinfo->WKT[WKT2_2019] = strdup(prj);
// printf("WKT2_2019: %s\n", tinfo->WKT[WKT2_2019]);
prj = (char *) proj_as_wkt(0, tmp, PJ_WKT1_GDAL, opts);
tinfo->WKT[WKT1_GDAL] = strdup(prj);
// printf("WKT1_GDAL: %s\n", tinfo->WKT[WKT1_GDAL]);
prj = (char *) proj_as_wkt(0, tmp, PJ_WKT1_GDAL, lopts);
tinfo->WKT[WKT1_LAS] = strdup(prj);
// printf("WKT1_LAS: %s\n", tinfo->WKT[WKT1_LAS]);
prj = (char *) proj_as_wkt(0, tmp, PJ_WKT1_ESRI, opts);
tinfo->WKT[WKT1_ESRI] = strdup(prj);
// printf("WKT1_ESRI: %s\n", tinfo->WKT[WKT1_ESRI]);
prj = (char *) proj_as_proj_string(0, tmp, PJ_PROJ_5, opts);
tinfo->WKT[PROJ5] = strdup(prj);
// printf("PROJ5: %s\n", tinfo->WKT[PROJ5]);
prj = (char *) proj_as_projjson(0, tmp, opts);
tinfo->WKT[PROJJSON] = strdup(prj);
// printf("PROJJSON: %s\n", tinfo->WKT[PROJJSON]);
proj_destroy(tmp);
return(ISOK);
On Fri, Jan 31, 2025 at 1:56 PM Tony Beckett via PROJ
<proj at lists.osgeo.org> wrote:
> Hi there,
> I’m trying to convert a Python coordinate conversion calculator (that I wrote a few years back) into C++.
> I have the basic code working, but I am struggling with how to extract a string containing the WKT for the source and target CRS.
> Can anyone provide me with a simple example, using the example app in the docs “Quick start for C++ API usage”. I’m assuming that the function ‘proj_as_wkt(…)’ is what is needed.
> Regards,
> Tony Beckett
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Roger Oberholtzer
More information about the PROJ
