[PROJ] PROJ 9.6.1RC1 & PROJ-data 1.22RC1
Kristian Evers
kristianevers at gmail.com
Sun Jun 1 22:21:20 PDT 2025
PSC members,
I forgot to start at vote for the promotion of the two RCs to final releases in good time. Seeing as there’s been no concerning
reports on either of them I hope that everyone can accept a speedy process so we can get the releases out later
today.
I’ll start with my +1.
/Kristian
> On 25 May 2025, at 21.27, Kristian Evers <kristianevers at gmail.com> wrote:
> All,
> PROJ 9.6.1 and PROJ-data 1.22 are coming up for release shortly. In preparation for that here is a round
> of release candidates for you to test.
> The PROJ-data release includes
> * Dutch grids for height conversions
> * The Japanese JPGEO2024 geoid
> * Latvian transformation grid for the LKS-2020 reference frame
> * Transformation grid for EVRF2019 in Denmark
> The release notes for the PROJ release can be found below.
> Download the release candidates here:
> https://download.osgeo.org/proj/proj-9.6.1RC1.tar.gz
> https://download.osgeo.org/proj/proj-9.6.1RC1.zip
> https://download.osgeo.org/proj/proj-data-1.22RC1.tar.gz
> https://download.osgeo.org/proj/proj-data-1.22RC1.zip
> As always, please report back your findings when testing the release candidates. Either here
> on the mailing list or as issue on GitHub.
> /Kristian
> # PROJ Release Notes
> ## 9.6.1
> ### Updates
> * Update EPSG to 12.012 (#4498)
> * Add an option to ship PDB files (#4505)
> ### Bug Fixes
> * Deal with South Orientated TMerc presented as regular TMerc but with Scale_Factor=-1 (#4427)
> * Add missing 'limits' and 'algorithm' includes (#4444)
> * CMake: avoid detection of C23 `#embed` on too old compilers (#4463)
> * `createOperations()`: for NAD83(CSRS)[x] to NAD83(CSRS)[y], do not go through NAD83 (#4467)
> * Add missing include for `uint32_t` on Windows with gcc 15.1 (#4478)
> * `getGeoidModels`: use vertical_crs.datum_code to get vcrss that uses different units (#4480)
> * `FileManager::open_resource_file()`: honour known URLs from grid_alternatives that don't point to cdn.proj.org (#4481)
> * Database: update ESRI to ArcGIS Pro 3.5 (#4493)
> * `createOperationsCompoundToGeog()`: avoid bringing non-sensical transformations (#4494)
> * Bug correction in Wagner VI projection parameters (#4453)
> * C++: Fix bare `isnan()` to `std::isnan()` (#4472)
> * Database: fix duplicated entries with auxiliary database (#4482)
> * Use `std::abs` instead of `abs` for NetBSD (#4486)
> * Fix Windows build when both `EMBED_RESOURCE_FILES` and `USE_ONLY_EMBEDDED_RESOURCE_FILES` are set (#4508)
More information about the PROJ
