[PROJ] PROJ 9.6.1RC1 & PROJ-data 1.22RC1
Howard Butler howard at hobu.co
Mon Jun 2 04:42:13 PDT 2025
+1 Howard
> On Jun 2, 2025, at 5:41 AM, Charles Karney via PROJ <proj at lists.osgeo.org> wrote:
> +1 Charles
> On 6/2/25 1:21 AM, Kristian Evers via PROJ wrote:
>> PSC members,
>> I forgot to start at vote for the promotion of the two RCs to final releases in good time. Seeing as there’s been no concerning
>> reports on either of them I hope that everyone can accept a speedy process so we can get the releases out later
>> today.
>> I’ll start with my +1.
>> /Kristian
>>> On 25 May 2025, at 21.27, Kristian Evers <kristianevers at gmail.com> wrote:
>>> All,
>>> PROJ 9.6.1 and PROJ-data 1.22 are coming up for release shortly. In preparation for that here is a round
>>> of release candidates for you to test.
>>> The PROJ-data release includes
>>> * Dutch grids for height conversions
>>> * The Japanese JPGEO2024 geoid
>>> * Latvian transformation grid for the LKS-2020 reference frame
>>> * Transformation grid for EVRF2019 in Denmark
>>> The release notes for the PROJ release can be found below.
>>> Download the release candidates here:
>>> https://download.osgeo.org/proj/proj-9.6.1RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-9.6.1RC1.zip
>>> https://download.osgeo.org/proj/proj-data-1.22RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-data-1.22RC1.zip
>>> As always, please report back your findings when testing the release candidates. Either here
>>> on the mailing list or as issue on GitHub.
>>> /Kristian
>>> # PROJ Release Notes
>>> ## 9.6.1
>>> ### Updates
>>> * Update EPSG to 12.012 (#4498)
>>> * Add an option to ship PDB files (#4505)
>>> ### Bug Fixes
>>> * Deal with South Orientated TMerc presented as regular TMerc but with Scale_Factor=-1 (#4427)
>>> * Add missing 'limits' and 'algorithm' includes (#4444)
>>> * CMake: avoid detection of C23 `#embed` on too old compilers (#4463)
>>> * `createOperations()`: for NAD83(CSRS)[x] to NAD83(CSRS)[y], do not go through NAD83 (#4467)
>>> * Add missing include for `uint32_t` on Windows with gcc 15.1 (#4478)
>>> * `getGeoidModels`: use vertical_crs.datum_code to get vcrss that uses different units (#4480)
>>> * `FileManager::open_resource_file()`: honour known URLs from grid_alternatives that don't point to cdn.proj.org (#4481)
>>> * Database: update ESRI to ArcGIS Pro 3.5 (#4493)
>>> * `createOperationsCompoundToGeog()`: avoid bringing non-sensical transformations (#4494)
>>> * Bug correction in Wagner VI projection parameters (#4453)
>>> * C++: Fix bare `isnan()` to `std::isnan()` (#4472)
>>> * Database: fix duplicated entries with auxiliary database (#4482)
>>> * Use `std::abs` instead of `abs` for NetBSD (#4486)
>>> * Fix Windows build when both `EMBED_RESOURCE_FILES` and `USE_ONLY_EMBEDDED_RESOURCE_FILES` are set (#4508)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> Charles Karney <karney at alum.mit.edu>
> 702 Prospect Ave
> Princeton, NJ 08540-4037
> PROJ mailing list
More information about the PROJ mailing list
