[PROJ] Determine "cut line" for arbitrary projection
Nyall Dawson nyall.dawson at gmail.com
Fri Mar 7 22:30:24 PST 2025
Hi list,
A question: given an arbitrary projection/CRS, is it possible to determine
the latitude (or projected x coordinate) at which features would need to be
"cut" in order to avoid artifacts when those features wrap around the
projection extremes.
Eg if it was EPSG:4326, we'd need to cut the features at +/- 180. But if
it's another projection... say mercator or spilhaus or ... is there any way
to reliably determine this cutting line?
Nyall
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250308/086f3da9/attachment.htm>
More information about the PROJ mailing list
