[PROJ] Geoid model in projected CRS
    Even Rouault
    even.rouault at spatialys.com
    Wed Mar 12 06:36:39 PDT 2025
Javier,
> Is there already a way to define a geoid model interpolated in
> projected coordinates?
> (some "small" countries, with just one projection, define their geoid
> models in that projected CRS. Recreating the grid in a geographic one
> adds some error)
> I see that
> https://proj.org/en/stable/operations/transformations/gridshift.html
> was added in 9.2.0, but I only see these options:
> HORIZONTAL_OFFSET,
> GEOGRAPHIC_3D_OFFSET,
> ELLIPSOIDAL_HEIGHT_OFFSET,
> VERTICAL_OFFSET_GEOGRAPHIC_TO_VERTICAL,
> VERTICAL_OFFSET_VERTICAL_TO_VERTICAL.
> I am not sure if any of those apply as
> "VERTICAL_OFFSET_PROJECTED_TO_VERTICAL".
This is a bit untested area. VERTICAL_OFFSET_GEOGRAPHIC_TO_VERTICAL
should be the one to use I believe.
> In case it is possible, how would be the insertion of the
> transformation in proj.db? (something like
> https://github.com/OSGeo/PROJ/blob/master/data/sql/grid_transformation_custom.sql#L71)
You likely need to use a PROJString with +proj=gridshift +grids=...
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250312/d906a699/attachment.htm>
More information about the PROJ
