[PROJ] Conda for PROJ
Mike Taves
mwtoews at gmail.com
Sun Mar 16 13:46:38 PDT 2025
Conda-forge doesn't really go through the release candidate stage
testing rounds (or I haven't seen it), so the final release is what
triggers the process for a new version on conda-forge. This means
there are sometimes new build issues that need patching or
work-arounds, which add to a time lag after the source release.
In this particular instance, there is a new and unknown error with
running nke.gie on ppc64le. It's not worth the developer time to
resolve this issue, as I'm guessing there are very few ppc64le
conda-forge users that need high accuracy in Northern Europe (and if
there are, now is your time to help resolve one of a few issues).
As for OSGeo4W, I've created https://trac.osgeo.org/osgeo4w/ticket/875
to task these updates.
Cheers, Mike
On Mon, 17 Mar 2025 at 01:57, Michael Smith via PROJ
<proj at lists.osgeo.org> wrote:
> Jovier,
> There is a PR to update the conda package with 9.6.0 at https://github.com/conda-forge/proj.4-feedstock/pull/153. Looks like were some issues with the build that now look to be fixed so I would expect this to be merged soon and the conda packages updated.
> Mike
> Michael Smith
> RSGIS Center – ERDC CRREL NH
> US Army Corps
> From: PROJ <proj-bounces at lists.osgeo.org> on behalf of Javier Jimenez Shaw via PROJ <proj at lists.osgeo.org>
> Reply-To: Javier Jimenez Shaw <j1 at jimenezshaw.com>
> Date: Sunday, March 16, 2025 at 8:17 AM
> To: proj <PROJ at lists.osgeo.org>
> Subject: [PROJ] Conda for PROJ
> Hi
> When and how is proj added to conda-forge?
> I tried "conda install -c conda-forge proj" and it is installing
> conda-forge/linux-64::proj-9.5.1-h0054346_0
> I heard there are some dependency problems to be solved (in GDAL and maybe others), but I do not know the details.
> Thanks
> Javier
> PS my final purpose is to install QGIS with PROJ 9.6.0
More information about the PROJ
