[PROJ] Determine "cut line" for arbitrary projection
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon Mar 17 03:48:03 PDT 2025
On Mon, 17 Mar 2025 at 11:40, Lesparre, Jochem via PROJ <
proj at lists.osgeo.org> wrote:
> > A further question might be how the cutlines relate to the 'area of use'
> in the EPSG database, but I'm afraid the answer is that the area of use is
> a geodetic bounding box. It does seem that a projection database ideally
> would have this information.
> The 'area of use' is a polygon in the EPSG database. It is PROJ that
> converts this into a bounding box.
Not exactly. In the database it has a bounding box, like in this example
(from PostgreSQL_Data_Script.sql)
INSERT INTO epsg_extent (extent_code, extent_name, extent_description,
bbox_south_bound_lat, bbox_west_bound_lon, bbox_north_bound_lat,
bbox_east_bound_lon, iso_a2_code, iso_a3_code, iso_n_code,
vertical_extent_min, vertical_extent_max, vertical_extent_crs_code,
temporal_extent_begin, temporal_extent_end, remarks, information_source,
data_source, revision_date, change_id, deprecated) VALUES (1275,
'Netherlands - onshore', 'Netherlands - onshore, including Waddenzee, Dutch
Wadden Islands and 12-mile offshore coastal zone.', 50.75, 3.2, 53.7, 7.22,
'', '', Null, Null, Null, Null, '', '', '', 'IOGP', 'EPSG', '2024-06-26',
'2009.046 2011.082 2012.013 2014.024 2023.042', 0);
In addition to that there is an external (big) file with the definition of
those polygons.
Including those polygons in the database would make it unnecessarily big.
Cheers
Javier.
> Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de
> geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden
> van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you are not the intended recipient, you are notified that disclosing,
> copying, distributing or taking any action in reliance on the contents of
> this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products and
> services
> [https://www.kadaster.com/general-terms-and-conditions].
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250317/4014deab/attachment.htm>
More information about the PROJ
