[PROJ] NTRIP-catalog
Mircea Neacsu
mircea at neacsu.net
Tue Mar 25 06:46:04 PDT 2025
Hi Javier,
I find your project a valuable initiative. I see it mostly as a verification tool, not as an automatic CRS selection tool. In most cases the CRS selection is imposed by other considerations and the NTRIP corrections have to match that selection.
In regard to other comments on the list: the way I see it, information about the CRS associated with a corrections stream should have been included in NTRIP protocol. The fact that now it exists in RTCM 3.4, is good but it's not the proper place. Once you have selected a corrections stream you can only check that corrections match your intended CRS. Besides, what if you need corrections in a different format (CMR or something else)? My view is that this information should be provided by the NTRIP casters.
I think NTRIP 2.0 (aka RTCM 10410.1) is becoming a little long in tooth and maybe a new version would improve on the format of the casters source table replacing the current CSV format with something more structured like JSON.
In the meantime, your tool can provide this missing information.
Cheers,
Mircea
---- On Thu, 20 Mar 2025 10:01:27 -0400 Javier Jimenez Shaw via PROJ <proj at lists.osgeo.org> wrote ---
Hi
This is not exactly a PROJ topic, but it's very related to CRS.
(I go to FOSSGIS in Münster next week, in case anybody want to talk with me directly. To Mostar in July as well)
TL;DR
If you are an NTRIP provider or developer of a NTRIP software, go to the link below. If you know somebody that is, please forward them this email. If none of the above, probably you do not care (but you can keep reading ;).
https://github.com/Pix4D/ntrip-catalog
I have been developing this open source / open data project to properly and easily identify the CRS for an NTRIP provider. The idea is that the providers (or people with that knowledge) add the information to this repository. Software that is using an NTRIP connection uses that information. And then everything works automagically for the user, that does not have to select anything (because they usually they don't know what to select, and do something wrong).
So far there are the json schema, some examples, scripts, documentation, tests (I want to add more). We developed it based on our own experience, but we know there are many, many corner cases. I would like to hear comments and proposals to improve it... in addition to more NTRIP provider information ;)
This is the typical win-win (open source) project that works when many parts contribute. Please, share this email if you know anybody that could be interested or has useful information.
When the project gets some traction the plan is to move it to the OSGeo Github organization, if they accept it.
Thank you,
Javier.
PROJ mailing list
mailto:PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250325/f51ac706/attachment-0001.htm>
More information about the PROJ
