[PROJ] NTRIP-catalog
Mircea Neacsu mircea at neacsu.net
Wed Mar 26 06:14:26 PDT 2025
I see that for the most part we managed to understand each other :)
> This does not specify the name of the RTN (MaCORS), the organization
> (Massachusetts Department of Transportation), and it does not
> specify the location of "the" base station.
Except that is does: latitude 42.27N, longitude 70.05W. They obviously don't make much sense in the context of a VRS network, but that's what the NTRIP standard requires. The name of operator and caster identifier are part of the CAS record not the STR record.
I think we all could agree that NTRIP specification would benefit from an update that uses a structured data format instead of CSV.
Cheers,
Mircea
---- On Tue, 25 Mar 2025 18:31:11 -0400 Greg Troxel via PROJ <proj at lists.osgeo.org> wrote ---
Mircea Neacsu via PROJ <mailto:proj at lists.osgeo.org> writes:
>> Then, using a GNSS receiver, it's going to get coordinates in some CRS.
>> Even without using NTRIP and injecting corrections/reference-data,
>> exactly what CRS is a difficult question.  Today, it could be
>> WGS84(G2296), or it could be some ITRF if using WAAS or EGNOS.  Once you
>> inject corrections, it could be quite a variety of CRSes.
>> I don't see how "the NTRIP corrections have to match".  What's available
>> is going to be constrained.
> Again I totally agree with you. However if corrections don't match the
> project CRS, most users would not want to have a datum transformation
> automatically applied without them being notified. I for one, would
> hate to have software do a DT without me saying so. That is why I said
> that I see Javier's database as a verification tool. I'd like the
> software popping a big red flag saying "Wait! your GPS corrections
> don't match the project CRS! What should I do?"
If your software also throws an exception/question when it loads any
data layer not in the project CRS that makes sense.
As to whether most users want transforms or popups, I think we have to
say it varies and both approaches have to be feasible.
>> NTRIP is simply a way to ask for a corrections stream.
> Not only. It also gives you some additional information like
> organization supplying those, location of base station, if you need to
> send a GGA sentence, bit rate, and so on. It would be nice if the CRS
> of those corrections would be part of that info.
Sort of true.  A real example from a professional NTRIP server (the
mountpoint I actually use):
STR;RTCM3MSM_IMAX;RTCM3MSM_IMAX;RTCM 3;;2;GPS+GLO+GAL+BDS;;;42.27;-71.05;1;1;Leica GNSS Spider;none;B;Y;9600;
specify the location of "the" base station.  Really there are more than
a dozen bases and you get a network solution, iMAX.  You only know that
by guessing from RTCM3MSM_IMAX which is a name in the protocol, after
interpreting it as a human.
Not apparent, but perhaps quite important, is that this stream is MSM4
and not MSM7.
> With NTRIP casters you have no way to a priori know the CRS of a
> stream. I agree that having CRS info in the stream itself  is very
> useful , but if you have to choose what stream to use from the 100+
> streams advertised by a caster, checking them one by one to find the
> proper CRS very difficult.  You could check them using Javier's
> database, but I still believe it would be simpler if casters would
> directly provide that information.
I see your point that knowing the CRS could be helpful and thus it would
be nice if NTRIP 3 included it.  There are many other issues, like
single base vs VRS/iMAX/MAC.  More complex networks will likely have
even more choices.
I don't think having the CRS in NTRIP is a good reason to refrain from
putting it in the stream itself.  If the stream carries base station
coordinates, as it does, it should also carry a frame identifier.  And,
someone might have a gateway that extracts the stream from NTRIP and
then uses radios.
PROJ mailing list
mailto:PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250326/fe3749d9/attachment-0001.htm>
More information about the PROJ mailing list
