[PROJ] bound + compound + derived vertical
Even Rouault even.rouault at spatialys.com
Thu Nov 13 09:56:28 PST 2025
Hi Javier,
Do you try to transform from that coumpound of bound to  MGI 3D ? If
so,that's probably a limitation in the current implementation of
CoordinateOperationFactory::Private::createOperationsCompoundToGeog().
Around line 6026 of coordinateoperationfactory.cpp, there's a case that
deal with a similar beast but only if transforming to "another CRS whose
datum is not the same as the horizontal datum of the source".  That
might be "just" a matter of tweaking that code to remove that
restriction. Or something else :-)
Even
Le 13/11/2025 à 17:26, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> I want to create a WKT2 to define a CRS with some specific conditions.
> For context, it is a horizontal (translation, rotation and scale) and
> vertical (offset and slope) transformation over a Gauß-Krugger over
> MGI, but MGI is defined by the Helmert transformation, and not by the
> grid file.
> To ensure that the Helmert transformation is done, I am creating a
> BOUNDCRS with those parameters.
> Inside the SOURCECRS I made a Compound with a derived projected and a
> derived vertical.
> That would allow me to include a proj pipeline with the horizontal
> correction, and use the derived vertical (using the Ellipsoid datum)
> to apply a vertical offset and slope.
> Not a small WKT2, but doable. I just have to copy the parameters I
> have in a json in the proper places, and it should work. But no, the
> vertical offset and slope is not applied.
> Do you know why?
> Ok, I thought that I can add the vertical component inside the
> derivingconversion of the baseprojcrs. If I add "+step +proj=affine
> +zoff=0.55429" it works fine. But I need to add an slope, something like
> "+step +proj=vertoffset +lat_0=48 +lon_0=12 +dh=0.55429
> +slope_lat=1.234 +slope_lon=0.234"
> But no. vertoffset works over a geodetic system, and the deriving
> conversion output is a cartersian projected system.
> In other examples have seen that the vertoffset pipeline is applied
> before the projection. How can I do it? Any idea why is it failing and
> how can I work it around?
> I can supply some WKT2s with my trials. They are big.
> Thank you
> Javier
> PS If you reached here, I have a present for you: in vscode
> or vscodium, you can format a WKT with "ini" format. The brackets are
> colored, and it makes easier to detect mistakes.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
