[PROJ] PROJ 9.7.1RC1 & PROJ-data 1.24RC1
Even Rouault
even.rouault at spatialys.com
Fri Nov 28 04:53:26 PST 2025
Hi Kristian,
+1 Even
Le 28/11/2025 à 12:56, Kristian Evers via PROJ a écrit :
> PSC members,
> I have received no reports of problems with the release candidates. You know the drill, I need some +1's ones to proceed with the final releases on Monday.
> I'll start with my own: +1.
> /Kristian
> On Tuesday, November 25th, 2025 at 11:07, Kristian Evers <kristian at evers.dev> wrote:
>> Everyone,
>> It’s once again time for a round of releases of the PROJ and PROJ-data packages. I’ve prepared
>> release candidates for both, which can be downloaded from
>> https://download.osgeo.org/proj/proj-9.7.1RC1.tar.gz
>> https://download.osgeo.org/proj/proj-9.7.1RC1.zip
>> https://download.osgeo.org/proj/proj-data-1.24RC1.tar.gz
>> https://download.osgeo.org/proj/proj-data-1.24RC1.zip
>> The PROJ-data release adds a grids for the
>> * Czech S-JTSK / Krovak East North to S-JTSK/05 / Modified Krovak East North transformation
>> * Norwegian vertical transformation from NN54 to NN2000 height
>> * French RGM23 to IGN 2023 Mayotte height transformation
>> Details for the PROJ release can be found below.
>> Please report any issues you may find with the release candidates, either here
>> on the mailing list or in issues on GitHub.
>> /Kristian
>> # PROJ Release Notes
>> ## 9.7.1
>> ### Updates
>> * Enable transformations_czechia.sql (#4578)
>> * Update to EPSG v12.029 (#4586)
>> ### Bug Fixes
>> * `createOperations()`: fix compound to compound when vertical CRS definition is equivalent but not strictly identical (#4579)
>> * `createOperations()`: fix compound to compound when horizontal CRS of … (#4582)
>> * `projinfo`: make it honour `-k crs` (#4592)
>> * `proj_clone()`: fix insufficient propagation of `FORCE_OVER=YES` (#4595)
>> * `BoundCRS::identify`: fix creation of an invalid BoundCRS (that can cause later crashes) for CRS based on 'NTF (Paris)' (#4601)
>> * WKT/PROJJSON datum ensemble import: allow no members (#4615)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ
