[PROJ] PROJ 9.7.0RC1 & PROJ-data 1.23RC1
    Kristian Evers
    kristian at evers.dev
    Mon Sep  8 12:22:59 PDT 2025
All,
in preparation for a new round of PROJ and PROJ-data release I have uploaded release candidates for both packages.
Download the archives here:
https://download.osgeo.org/proj/proj-9.7.0RC1.tar.gz
https://download.osgeo.org/proj/proj-9.7.0RC1.zip
https://download.osgeo.org/proj/proj-data-1.23RC1.tar.gz
https://download.osgeo.org/proj/proj-data-1.23RC1.zip
The PROJ release includes both updates and bug fixes. See the release notes below.
The PROJ-data release comes with the following additions:
* Slovenian height conversion grid, SVS2000 to SVS2010
* Norwegian ETRS89 transformation grid covering Svalbard
Please test the release candidates and report any issues you may find with them.
Either here on the mailing list or on GitHub.
/Kristian
# PROJ Release Notes
## 9.7.0
### Updates
* Implement 'exact' authalic latitude->geographic latitude and use it in `+proj=aea/cea/laea/eqearth/healpix/rhealpix` (#4441)
* Implement uniform conversions between auxiliary latitudes (#4446)
* WKT2 parser: recognize `DEFININGTRANSFORMATION` (but ignore it) (#4484)
* Database: add values from `alias_name` table that were removed in older EPSG releases, to improve
recognizing old WKT strings (#4490)
* `proj_trans_bounds()`: sample points within the source grid to avoid missing extent such as world-wide
coverage from EPSG:4326 to ESRI:54099 (Spilhaus) (#4513)
* Enable `-Wimplicit-fallthrough`, `-Wdeprecated-copy-dtor`, `-Wweak-vtables`,
`-Wdocumentation-unknown-command` when possible (#4516)
* Geostationary projection: speed up inverse spherical and ellipsoidal computation (#4523)
* WKT importer: better error message when `BBOX` is invalid (e.g south_lat > north_lat) (#4525)
* Added `proj_geod_direct` for PJ trasformation object (#4532)
* Support exporting Mercator (Spherical) on a sphere as `Mercator_1SP` in WKT1 (#4555)
* Database: update to EPSG v12.022 (#4562)
### Bug Fixes
* `proj_trans_bounds()`: avoid erroring out, in some cases, when PJ* object is directly constructed
from a PROJ pipeline (#4512)
* Fix issue related to `D_Unknown_based_on_WGS_84_ellipsoid` datum name (#4515)
* `proj_trans_bounds()`: fix 9.6.2 regression when going from long/lat crossing antimeridian to
projected (#4526)
* opt_parse: avoid potential heap-buffer-overflow when parsing non-ASCII characters (affect
`cct` and `gie`) (#4530)
* `gie`: fix memory leak on non existing input file (#4531)
* Database: referene `nl_nsgi_nllat2018.tif` and `nl_nsgi_bongeo2004.tif` grids (#4534)
* Fixes related to WKT import/export of `DerivedGeodetic/GeographicCRS` (#4536)
* Fix `tolower()`/`toupper()` implementation to not lead to undefined behavior (#4539)
* IAU2015 CRS: fix wrong code for coordinate system of North Polar and South Polar CRSs (#4545)
* `createOperations()`: fix a case involving 2 CompoundCRS, one with TOWGS84, and the 2
verticalCRS differing by units (#4552)
* On SQLite query error, show first the error msg than the sql query (#4553)
* Allow geodesic inverse for meridional points on prolate ellipsoid (#4560)
More information about the PROJ
