[PROJ] PROJ 9.7.0RC1 & PROJ-data 1.23RC1
    Kristian Evers
    kristian at evers.dev
    Mon Sep  8 23:23:52 PDT 2025
> I locally updated pkgsrc on NetBSD 10 amd64.
> Builds and packages fine, and tests pass.
> I started up qgis and my data still lines up.
> The updated proj-data package has the two new files in your
> announcement.
> So looks good to release, from where I sit.
That’s great to hear, thanks for the feedback.
> Not about this release, but triggered by my preparing the RC package:
> We have a longstanding proj-docs package that intends to have a pdf of
> the manual, and it's been broken since 9.2ish. I see that one can
> obtain a pdf at
> https://proj.org/_/downloads/en/9.6/pdf/
> which is unfortunately named for systems expecting to store a file
> proj-doc-9.6.pdf, even though formally there are no rules. I managed to
> work around this, but it would be nice if the URL looked something like
> https://proj.org/_/downloads/en/proj-doc-9.6.pdf
> Not important, probably all the packagers have already coped, and that
> is likely baked into rtd.
I honestly have no idea if this is possible with RTD. It might not be.
You could build the PDF yourself by running
make pdf
in docs/. You’ll have to have sphinx setup of course.
/Kristian
> PROJ mailing list
> PROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250909/5f16e4a3/attachment.htm>
More information about the PROJ
