[PROJ] EPSG:4326 --> EPSG:5677
    Even Rouault
    even.rouault at spatialys.com
    Wed Sep 24 01:57:04 PDT 2025
Robert,
the more precise transformation between both datums involves the use of
this grid file : https://cdn.proj.org/de_adv_BETA2007.tif . Make sure it
is installed in the same directory where proj.db is located
cf:
$ projinfo EPSG:4326 EPSG:5677 --spatial-test intersects --grid-check
none -o PROJ
Candidate operations found: 3
Operation No. 1:
unknown id, Inverse of DHDN to WGS 84 (4) + 3-degree Gauss-Kruger zone
3, 1 m, Germany - onshore - states of Baden-Wurtemberg, Bayern, Berlin,
Brandenburg, Bremen, Hamburg, Hessen, Mecklenburg-Vorpommern,
Niedersachsen, Nordrhein-Westfalen, Rheinland-Pfalz, Saarland, Sachsen,
Sachsen-Anhalt, Schleswig-Holstein, Thuringen., at least one grid missing
PROJ string:
+proj=pipeline
   +step +proj=axisswap +order=2,1
   +step +proj=unitconvert +xy_in=deg +xy_out=rad
   +step +inv +proj=hgridshift +grids=de_adv_BETA2007.tif
   +step +proj=tmerc +lat_0=0 +lon_0=9 +k=1 +x_0=3500000 +y_0=0
+ellps=bessel
Grid de_adv_BETA2007.tif needed but not found on the system. Can be
obtained at https://cdn.proj.org/de_adv_BETA2007.tif
Even
Le 24/09/2025 à 08:57, Roger Oberholtzer via PROJ a écrit :
> I am trying to project some EPSG:4326 locations (from a GPS) to
> EPSG:5677 (DHDN Germany Zone 3). I have sample data from the German
> road authorities (BASt). They feel that the locations provided by proj
> (9.6.0) are consistently 1.5 meters or so away from that they expect.
> They were also expecting a change in altitude as the ellipsoid was
> different. I have implemented this with something like this:
> myCRS = proj_create_crs_to_crs( 0,  "EPSG:4326",  "EPSG:5677",  0);
> And then calling proj_trans(myCRS, PJ_FWD, PJ_COORD);
> My question is if I need to do more than this as EPSG:5677 is
> ellipsoid Bessel 1841.
> Roger Oberholtzer
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250924/4ca8486b/attachment-0001.htm>
More information about the PROJ
