[PROJ] PROJ 9.8.1 release candidate and motion to approve it
Kristian Evers
kristian at evers.dev
Thu Apr 9 05:12:11 PDT 2026
Howard,
I don't think we will gain anything by lagging behind by x months of EPSG releases. No one else is testing their releases in real time (as far as I know), so we would just find the same issues at a later date.
I think our best chance for now is to improve testing on our side as much as possible, as well as providing the means for non-techy geodesist to tests stuff in development. The first part I think we can start acting on right away, and perhaps even coordinate with the EPSG folks somehow. The second part would require pre-release binaries to be easy to access, as I don't think we can expect that geodesy experts are able to compile PROJ from source. This meshes well with previous talks on automating the release process.
/Kristian
On Thursday, April 9th, 2026 at 13:49, Howard Butler via PROJ <proj at lists.osgeo.org> wrote:
>> On Apr 8, 2026, at 7:12 AM, Even Rouault via PROJ <proj at lists.osgeo.org> wrote:
>> Starting with my +1
> +1 Howard
> Should PROJ consider implementing some kind of lag in its uptake of EPSG databases? Maybe it wouldn't have mattered in this case, however.
> "A lot of luck to whoever want to put together the computational part of the datum shift software." – Gerry Eveneden [1]
> [1] https://howardbutler.com/files/history-of-proj4-foss4g2017-howard-butler.pdf
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260409/8ad4c4c5/attachment.htm>
More information about the PROJ
