[PROJ] PROJ 9.8.1 release candidate and motion to approve it
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Apr 9 06:08:05 PDT 2026
+1 Javier
On Thu, 9 Apr 2026 at 13:11, Charles Karney via PROJ <proj at lists.osgeo.org>
wrote:
> +1 Charles
> > On Apr 8, 2026, at 08:12, Even Rouault via PROJ <proj at lists.osgeo.org>
> wrote:
> > Hi,
> > I've prepared a release candidate for PROJ 9.8.1, ahead of the planned
> schedule, to address the ETRS89 related issues mentioned in the below
> release notes.
> > Download the archives here:
> > https://download.osgeo.org/proj/proj-9.8.1RC1.tar.gz
> > https://download.osgeo.org/proj/proj-9.8.1RC1.zip
> > Community members, please report any issue.
> > PSC members, please test and cast your vote to promote it to final 9.8.1
> > Starting with my +1
> > Even
> > ## 9.8.1
> > ### Warning
> > It was discovered after the PROJ 9.8.0 release that several EPSG updates
> introduced
> > after EPSG v12.033 - notably the introduction of national realizations
> of ETRS89
> > (ETRS89-XXX […] where XXX is the 3-letter ISO country code) - caused
> backward
> > incompatibilities in some workflows involving the ETRS89 CRS.
> > In particular, transformations between ETRS89 and national CRSs based on
> other
> > datums are known to be affected for Austria, Belgium, Catalonia, the
> Netherlands,
> > Romania, and Serbia. See #4736 for more details.
> > While we intend to resume tracking the latest EPSG releases in future
> PROJ
> > versions, the safest solution identified so far to address these
> regressions is to
> > **revert the EPSG related content of its database from EPSG v12.049 to
> v12.029**,
> > where v12.029 was the version distributed with PROJ 9.7.1
> > As a consequence of this revert, the EPSG datum and CRS records
> introduced in
> > PROJ 9.8.0, which are mostly related to the new ETRS89-XXX datum and
> CRS, are no
> > longer available in PROJ 9.8.1.
> > ### Updates
> > * Database: **Revert content from EPSG v12.049 to v12.029** (#4741).
> >   See above warning for more details.
> > * CMake: handle deprecated SQLite::SQLite3 target in CMake 4.3 (#4694)
> > ### Bug Fixes
> > * Make sure that epoch is set in more scenarios of time-dependent
> transformations (#4688)
> > * pj_obj_create: use database context if already open for grid name
> resolution (#4703)
> > * Chain vertical CRS transformations through intermediate same-datum
> vertical CRS (#4711)
> >   Helps for example for **EPSG:5705** (Baltic 1977 height) to
> **EPSG:5706** (Caspian depth)
> >   by using intermediate operation from Baltic 1977 height to Caspian
> *height*
> > http://www.spatialys.com
> > My software is free, but my time generally not.
> > PROJ mailing list
> > PROJ at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260409/66b2511d/attachment-0001.htm>
More information about the PROJ mailing list
