[PROJ] PROJ 9.8.1 release candidate and motion to approve it
SIMON Nicolas nicolas.simon at spw.wallonie.be
Thu Apr 9 07:48:46 PDT 2026
Hi
+1 Nicolas, from/for Belgium
As Even mentioned in https://github.com/OSGeo/PROJ/pull/4736, the changes proposed by EPSG raised a red flag.
Thanks for this new release.
Nicolas
-----Message d'origine-----
De : PROJ <proj-bounces at lists.osgeo.org> De la part de Even Rouault via PROJ
Envoyé : mercredi 8 avril 2026 14:12
À : proj <proj at lists.osgeo.org>
Objet : [PROJ] PROJ 9.8.1 release candidate and motion to approve it
I've prepared a release candidate for PROJ 9.8.1, ahead of the planned schedule, to address the ETRS89 related issues mentioned in the below release notes.
Download the archives here:
https://download.osgeo.org/proj/proj-9.8.1RC1.tar.gz
https://download.osgeo.org/proj/proj-9.8.1RC1.zip
Community members, please report any issue.
PSC members, please test and cast your vote to promote it to final 9.8.1
Starting with my +1
Even
## 9.8.1
### Warning
It was discovered after the PROJ 9.8.0 release that several EPSG updates introduced after EPSG v12.033 - notably the introduction of national realizations of ETRS89 (ETRS89-XXX [...] where XXX is the 3-letter ISO country code) - caused backward incompatibilities in some workflows involving the ETRS89 CRS.
In particular, transformations between ETRS89 and national CRSs based on other datums are known to be affected for Austria, Belgium, Catalonia, the Netherlands, Romania, and Serbia. See #4736 for more details.
While we intend to resume tracking the latest EPSG releases in future PROJ versions, the safest solution identified so far to address these regressions is to **revert the EPSG related content of its database from EPSG v12.049 to v12.029**, where v12.029 was the version distributed with PROJ 9.7.1
As a consequence of this revert, the EPSG datum and CRS records introduced in PROJ 9.8.0, which are mostly related to the new ETRS89-XXX datum and CRS, are no longer available in PROJ 9.8.1.
### Updates
* Database: **Revert content from EPSG v12.049 to v12.029** (#4741).
   See above warning for more details.
* CMake: handle deprecated SQLite::SQLite3 target in CMake 4.3 (#4694)
### Bug Fixes
* Make sure that epoch is set in more scenarios of time-dependent transformations (#4688)
* pj_obj_create: use database context if already open for grid name resolution (#4703)
* Chain vertical CRS transformations through intermediate same-datum vertical CRS (#4711)
   Helps for example for **EPSG:5705** (Baltic 1977 height) to
**EPSG:5706** (Caspian depth)
   by using intermediate operation from Baltic 1977 height to Caspian
*height*
http://www.spatialys.com/
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
