[PROJ] precise transformation from EPSG:4326 to EPSG:6706
Antonio Valanzano anvalanz at gmail.com
Mon Apr 27 09:52:46 PDT 2026
 On the application
https://jjimenezshaw.github.io/wasm-proj/projinfo.html
the following command:
projinfo -s EPSG:4326 -t EPSG:6706 -o proj --spatial-test intersects
 produces this output:
Candidate operations found: 1
Operation No. 1:
INVERSE(EPSG):6711, Inverse of RDN2008 to WGS 84 (1), *1.0* m, Italy -
onshore and offshore.
PROJ string:
+proj=noop
Does someone know if it is possible, using special options for cs2cs,  to
achieve a transformation with an accuracy better than *1.0 m* ?
Thanks in advance
Antonio Valanzano
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260427/49f90bab/attachment.htm>
More information about the PROJ mailing list
