[PROJ] Performance when Auxilary DB used
Even Rouault even.rouault at spatialys.com
Mon Aug 31 13:43:42 PDT 2026
Le 31/08/2026 à 22:34, Weston Renoud a écrit :
> Hey Even,
> Removing the ORDER BY clause removed the need to materialize and gives
> the same query performance as with the temporary tables, but without
> the need to create any temporary tables which took extra time. Adding
> back just the "ORDER BY score" still avoided the materialize, it
> seemed to be the "usage.auth_name, usage.code" that triggered the
> materialize. Are those necessary, or is "ORDER BY score" sufficient?
They are only necessary for reproducibility of results among SQLite
versions, in case of equality of score.  There is no guarantee otherwise
that different SQLite versions would return the same ordered result set.
So they would need to be replicated on the C++ side ( std::sort() with
an appropriate sort lambda)
http://www.spatialys.com
LLMs contribute to global warming and brain rot.
Let's guillotine them! "Ah ! ça ira, ça ira, ça ira !"
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260831/7a42a518/attachment.htm>
More information about the PROJ mailing list
