[PROJ] Unitconvert after topocentric conversion
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon Feb 9 05:06:10 PST 2026
Hi
I would like to compute the difference in a topocentric system (ENU) from
points in geocentric coordinates... with the output in millimetres.
echo 4000000.0000 300000.0000 5000001.0000 | cct +pipeline +step
+proj=topocentric +X_0=4000000.0000 +Y_0=300000.0000 +Z_0=5000000.0000
+step +proj=unitconvert +xy_in=m +xy_out=mm +z_in=m +z_out=mm
0.0000 0.6232 0.7820 inf
But that is exactly the same output if I do not do the unit conversion.
Am I doing something wrong?
Thanks.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260209/9082a1c6/attachment.htm>
More information about the PROJ
