[PROJ] Wrong transformation in NL?
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Mon Feb 23 01:11:39 PST 2026
Hi Even,
Amersfoort ellipsoidal heights were used in the past and could still be used under certain conditions. The transformation via 3D Amersfoort (your 1st example) taken here is needlessly complex (using the horizontal grid for the interpolation CRS of the geoid, but not for the horizontal coordinates), but it is correct within the accuracy. In the area of use, the maximum differences with the transformation via ETRS89-NLD [AGRS2010] recommended by the national authorities (your 2nd example) are 0.25 m horizontally and a few centimetres vertically.
Nevertheless, I'm still going to ask EPSG for changes that will favour or force transformation via ETRS89-NLD [AGRS2010] instead of 3D Amersfoort.
Regards, Jochem
1st example
$ echo 52 5 0 |  PROJ_NETWORK=ON bin/cs2cs -d 4 --3d EPSG:4326+3855 Amersfoort | PROJ_NETWORK=ON bin/cs2cs --3d -d 4 Amersfoort "Amersfoort + NAP height"
52.0010    5.0004 0.1953
2nd example
$ echo 52 5 0 |  PROJ_NETWORK=ON bin/cs2cs -d 4 EPSG:4326+3855 "Amersfoort + NAP height"
52.0010    5.0004 0.2000
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
More information about the PROJ mailing list
