[PROJ] Finding not implemented projections
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Feb 26 02:29:31 PST 2026
Hi
Today I met "by accident" EPSG:3053
https://spatialreference.org/ref/epsg/3053/
looking for a westing-northing system.
I realized that the projection "Lambert Conic Conformal (West Orientated)"
is not implemented (all fine, I don't want it to be implemented).
What I want to know is which CRSs from the catalog do not have an
implemented projection, to avoid using them.
We are using "proj_get_crs_info_list_from_database" to get the list of all
the systems (13722). It includes the field "projection_method_name" (a
string).
Is there any function in C or C++ API to know if such a method is
implemented? Doing a quick search in spatialreference I see there are 53
methods in total nowadays.
I don't want to hardcode that list in my code, in case anything changes in
the future.
Thank you.
Cheers
Javier.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260226/f80ce795/attachment-0001.htm>
More information about the PROJ mailing list
