[PROJ] EPSG release once more busted
Martin Desruisseaux martin.desruisseaux at geomatys.com
Tue Jul 21 16:17:34 PDT 2026
Le 21/07/2026 à 21:43, Even Rouault via PROJ a écrit :
> I'm trying to integrate the latest EPSG 12.059a release and there are
> *again* consistency errors. Not necessary big deals, usually I deal
> with that directly with them in a diplomatic way, but I'm fed up of
> that. What kind of pressure can we apply on EPSG so they implement
> them on their side ? I've pointed them multiple times to our sql
> scripts but it seams to fall on deaf ears.
Disclaimer: I'm not a member of the EPSG team, but I'm regularly in
touch with an EPSG maintainer in the context of ongoing ISO 19111 revision.
EPSG is in a position between developers and mapping agencies. I do not
know for 12.059a, but some issues reported as inconsistencies in
previous versions were actually explicit demands from mapping agencies
rather than errors. For example, there is the case of a missing epoch
for the CRS of a northern country (I forgot the details, sorry). It was
not an EPSG error, but a demand of that mapping agency who felt that in
their particular case, providing a single epoch would be misleading and
preferred to provide none rather than a misleading information. This
case has been discussed at length during the meetings of the ISO 19111
revision group a few months ago. The EPSG representative reported that
they were struggling about how to conciliate both developer's grief and
mapping agency concern in same time, and the group was considering
whether a change of ISO 19111 model would help.
The vast majority of the debate in the ISO 19111 group is about how to
improve our representation of the physical world, and whether a
perceived "improvement" of ISO 19111 is really correct. After an
agreement has been reached on geodesic grounds, the translation into
data structures (UML of classes and attributes) tends to be quite
consensual. While I do not know the internal of EPSG team work, I think
that they also focus mostly on the geodesic content, maybe at the cost
of compromises when a particular case does not fit nicely in the
database schema. I think that the bar for changing the schema is also
quite high, a little bit like changing a public API.
     Martin
More information about the PROJ mailing list
