[PROJ] EPSG release once more busted
Greg Troxel gdt at lexort.com
Wed Jul 22 03:37:55 PDT 2026
SIMON Nicolas via PROJ <proj at lists.osgeo.org> writes:
> Another aspect of the problem is the stability of the official definitions already in place.
> For the Belgian Lambert 2008 projection (EPSG:3812), the EPSG has defined a new projection with epochs (EPSG:11219).
I think the key question here is whether the Belgian
$(Geodetic_Authority) has changed the definition of an established name,
and EPSG is following, or if something else is going on.
In general, the situation projected CRSes with an underlying datum that
is an ensemble, or worse turned into an ensemble, is messy.
It's further messy if there is blurring of system and the ensemble of
frames implementing that system.
More information about the PROJ mailing list
