[PROJ] ETRFxx to national ETRS89 realizations (e.g. ETRS89-NLD [AGRS2010], RGF93 v2/v2b, ETRS89-HUN [ETRF2000], etc.) (was Re: Time dependency in ETRFxx to ETRFyy coordinate transformations?)
Even Rouault
even.rouault at spatialys.com
Sun Jun 21 14:52:45 PDT 2026
https://docs.ogc.org/as/18-005r8/18-005r8.pdf:
"""datum anchor epoch: epoch at which a static reference frame matches
a dynamic reference frame from which it has been derived. Note: Not to
be confused with the frame reference epoch of dynamic geodetic and
dynamic vertical reference frames. Nor with the epoch at which a
reference frame is defined to be aligned with another reference frame;
this information should be included in the datum anchor definition."
http://www.spatialys.com
LLMs contribute to global warming and brain rot
More information about the PROJ
