[PROJ] Creating a dynamic system
Even Rouault
even.rouault at spatialys.com
Sun Mar 1 14:56:06 PST 2026
for all practical purposes, it seems to be one. I don't know why it
hasn't been formally tagged as such in EPSG. I see that back in times I
added in CoordinateMetadata::create() an exception to check if a CRS had
a point motion operation attached to it to allow it to be used to create
a CoordinateMetadata object
Le 01/03/2026 à 23:46, Javier Jimenez Shaw a écrit :
> In your last PR https://github.com/OSGeo/PROJ/pull/4685/ you use
> "NAD83(CSRS)v7" as an example, but it does not have a dynamic datum.
> The datum is type 3, PJ_TYPE_GEODETIC_REFERENCE_FRAME.
> On Sun, 22 Feb 2026 at 18:32, Even Rouault
> <even.rouault at spatialys.com> wrote:
> Le 22/02/2026 à 15:28, Javier Jimenez Shaw via PROJ a écrit :
> > Hi
> > the C function proj_coordinate_metadata_create can
> https://proj.org/en/stable/development/reference/functions.html#c.proj_coordinate_metadata_create
> > allows to create a dynamic system with an epoch.
> > In case the crs is not dynamic, it fails and emits an error.
> > However I do not see how to check if a system is dynamic, to
> call it
> > only if really needed.
> > Is there such a function in the C API?
> checking proj_get_type() ==
> PJ_TYPE_DYNAMIC_GEODETIC_REFERENCE_FRAME on
> the result of proj_crs_get_datum()
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260301/b2d37a71/attachment.htm>
More information about the PROJ
