[PROJ] Problems adding geoidmodel tag
Even Rouault even.rouault at spatialys.com
Tue Mar 3 08:41:24 PST 2026
Javier,
not much you can do but not setting a manual geoid model for that case.
The pipeline used is highly manually tuned
from https://github.com/OSGeo/PROJ/blob/master/data/sql/transformations_czechia.sql#L99
and
https://github.com/OSGeo/PROJ/blob/master/data/sql/transformations_czechia.sql#L171
for operating on the CRS defined from the exact EPSG codes. Would be
very hard to make PROJ realize that your custom WKT would be
compatible of that pipeline
(The pipeline you get with the geoid model node is not fundamentally
wrong, just slightly less accurate w.r.t. CUZK recommends for most
geodesic proof ETRS89 to S-JTSK / Krovak)
Even
Le 03/03/2026 à 17:06, Javier Jimenez Shaw via PROJ a écrit :
> PROJ_NETWORK=ON projinfo EPSG:4258 EPSG:5514+8357 --3d -o proj --bbox
> 17.8,49,17.81,49.01
http://www.spatialys.com
More information about the PROJ mailing list
