[PROJ] Problems adding geoidmodel tag
Even Rouault
even.rouault at spatialys.com
Tue Mar 3 09:05:26 PST 2026
Le 03/03/2026 à 17:48, Javier Jimenez Shaw a écrit :
> How could I know in advance that it is not using the geoid model file
> from Slovakia? They (unfortunately) use the same vertical system, and
> the accuracy in both cases is 0.03 m
> https://epsg.org/transformation_10568/ETRS89-CZE-2007-to-ETRS89-CZE-2007-Baltic-1957-height-2.html
> https://epsg.org/transformation_8361/ETRS89-SVK-SKTRF09-to-ETRS89-SVK-SKTRF09-Baltic-1957-height-1.html
Depends on how you perform the coordinate operation itself. But if you
specify "--area Czechia" with cs2cs or use the PJ_AREA* member of
proj_create_crs_to_crs/proj_create_crs_to_crs_from_pj, you should only
get those for Czechia
http://www.spatialys.com
More information about the PROJ
