[PROJ] cs2cs options
Antonio Valanzano
anvalanz at gmail.com
Tue Mar 3 10:25:13 PST 2026
I have used for the first time cs2cs and I have found not easy to
discover which transformation the sw uses for the calculations.
Here are my questions:
1. Is it possible for cs2cs to output not only the results but also
the EPSG code of the transformation(s) used to produce the output ?
This information could be useful for users in order to have more
control over the transformations and avoid using the sw as a black
box.
2. Is it possible to specify, as an option of cs2cs, a particular
pipeline of transformations using the codes considered in the
Geographic Parameter of the EPSG ?
Antonio
More information about the PROJ
