[PROJ] cs2cs options
Even Rouault
even.rouault at spatialys.com
Wed Mar 4 09:28:20 PST 2026
Le 04/03/2026 à 18:24, Javier Jimenez Shaw a écrit :
> Thanks Even.
> But that is not always:
yes, in that case there's only one single pipeline possible (a map
projection without datum change) as reported by projinfo
> echo 40 0 | PROJ_DEBUG=2 ./cs2cs etrs89 epsg:25830
> pj_open_lib(proj.ini): call fopen(...proj.ini) - succeeded
> pj_open_lib(proj.db): call fopen(...proj.db) - succeeded
> 756099.65 4432069.06 0.00
> And I understand (way) better the proj pipeline ;)
> On Wed, 4 Mar 2026 at 18:12, Even Rouault <even.rouault at spatialys.com>
> wrote:
> Le 04/03/2026 à 18:09, Javier Jimenez Shaw via PROJ a écrit :
>> Hi Antonio.
>> On Tue, 3 Mar 2026 at 19:25, Antonio Valanzano via PROJ
>> <proj at lists.osgeo.org> wrote:
>> I have used for the first time cs2cs and I have found not easy to
>> discover which transformation the sw uses for the calculations.
>> Here are my questions:
>> 1. Is it possible for cs2cs to output not only the results
>> but also
>> the EPSG code of the transformation(s) used to produce the
>> output ?
>> This information could be useful for users in order to have more
>> control over the transformations and avoid using the sw as a
>> black
>> box.
>> There is projinfo https://proj.org/en/stable/apps/projinfo.html ,
>> that can give you similar information. But it would be nice to
>> have an option in cs2cs that prints the last operation used
>> calling "proj_trans_get_last_used_operation".
>> That way the user can know "exactly" the operation performed.
> $ echo 49 15 | PROJ_NETWORK=ON PROJ_DEBUG=2 bin/cs2cs EPSG:4258
> EPSG:5514+8357 --3d
> Using coordinate operation ETRS89 to S-JTSK / Krovak East North +
> Baltic 1957 height
> -717321.47 -1168433.34 -46.13
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260304/04bfc9d2/attachment.htm>
More information about the PROJ
