[PROJ] Is PROJ unreasonably slow?
Javier Jimenez Shaw
j1 at jimenezshaw.com
Thu Mar 12 12:40:40 PDT 2026
Hi Thomas
It took me some time to read the email. I hope it is not a revenge for my
last emails containing some explicit WKT2 ;)
That is good news! If a projection library, with all the trigonometric and
complicated functions it is calling, is affected by reading and writing
doubles in input/output, it means that the library is really efficient.
Maybe not in the parsing of the strings, but the rest it is.
When I started reading the email a while ago, my first reaction was "many
people say std streams are not efficient".
About caching grid files, we could probably add an environment variable
(read only once) to set the cache size to a value. That could give you some
flexibility requesting random points.
Remove compression? well, maybe the Swedish files are small. The new geoid
model for US will not fit in the size limit per file we have in GitHub. We
will have to do some tricks to include it (like use int16 instead of
float32).
In summary I agree with Even: command line apps are "toys" for
testing/playing. Can we improve that performance? Probably. Is it worth it?
I don't know. Is your fear that they use it to compare with other
libraries, and PROJ is minus-valued? Could be.
About grids in memory, there is always the trade off between memory
economics and performance. We can be more flexible for extreme cases as
yours.
Maybe I am missing other points inside the library where we are slow and we
can improve. Please, let me know.
Cheers
Javier.
On Wed, 11 Mar 2026 at 18:43, Even Rouault <even.rouault at spatialys.com>
wrote:
> Thomas,
> I don't know how you manage to write such long essays. Does my (non LLM
> generated) below summary reflect your findings:
> - Command line utilities are to be considered "toys" if you process a
> large amount of data and care about perf. Not that suprising, and I
> wouldn't expect anyone trying to use PROJ at its max perf capabilities
> to use them, but rather use the (binary) API. In GDAL, we use at some
> places the fast_float C++ header library for fast string->double :
> https://github.com/fastfloat/fast_float . They claim it can be up to
> about 4x faster than strtod(). We could also vendor in PROJ if needed.
> - Grid usage could be made much faster if we decompressed everything in
> memory. There's already a bit of caching of decompressed tiles. But
> random spatial access pattern will easily defeat it as it is quite
> modest currently. We could add an option to increase the cache to a
> specified size and/or increase the default size. I wouldn't trust too
> much OS virtual memory mapping. Can easily lead to crashing your
> system (or making it unusable at the point your need to hard reboot) if
> you map too much memory vs your available RAM.
> Even
> Le 11/03/2026 à 09:45, Thomas Knudsen a écrit :
> > TL;DR: Is PROJ unreasonably slow? The answer is "Mostly no", but with a
> few
> > caveats...
> > DISCLAIMER: The evidence presented below is weak - timing experiments
> repeated
> > only 2-4 times, on just a single computer. But at first sight the speed
> tests
> > all hint at the same conclusion: That PROJ could be made significantly
> faster.
> > Closer inspection, however, shows that, while in some corner cases, PROJ
> really
> > can be made faster, in the general cases, it already really is quite
> fast.
> ... deleted content.
> > But I would highly prefer to leave this kind of code to reside in system
> > libraries, not in an application library, like PROJ.
> > Nevertheless: Hope y'all will consider this (much too) long writeup, and
> give it
> > a deep thought, whether rearchitecting PROJ, and to what extent, may be
> worth
> > the effort.
> > /Thomas Knudsen
> > [1] Rust Geodesy: https://lib.rs/geodesy
> > https://github.com/busstoptaktik/geodesy
> > [2] kp:
> https://github.com/busstoptaktik/geodesy/blob/main/ruminations/003-rumination.md
> > [3] cs2cs: https://proj.org/en/stable/apps/cs2cs.html
> > [4] cct: https://proj.org/en/stable/apps/cct.html
> > [5] The ITRF2014->SWEREF99 transformation:
> > $ projinfo -o proj --hide-ballpark -s itrf2014 -t sweref99
> > +proj=pipeline
> > +step +proj=axisswap +order=2,1
> > +step +proj=unitconvert +xy_in=deg +xy_out=rad
> > +step +proj=cart +ellps=GRS80
> > +step +proj=helmert +x=0 +y=0 +z=0 +rx=0.001785 +ry=0.011151
> > +rz=-0.01617 +s=0
> > +dx=0 +dy=0 +dz=0 +drx=8.5e-05 +dry=0.000531 +drz=-0.00077
> +ds=0
> > +t_epoch=2010 +convention=position_vector
> > +step +inv +proj=deformation +t_epoch=2000
> +grids=eur_nkg_nkgrf17vel.tif
> > +ellps=GRS80
> > +step +proj=helmert +x=0.03054 +y=0.04606 +z=-0.07944
> +rx=0.00141958
> > +ry=0.00015132 +rz=0.00150337 +s=0.003002
> > +step +proj=deformation +dt=-0.5 +grids=eur_nkg_nkgrf17vel.tif
> > +ellps=GRS80
> > +step +inv +proj=cart +ellps=GRS80
> > +step +proj=unitconvert +xy_in=rad +xy_out=deg
> > [6] Rumination 012: Unigrids and the UG grid maintenance utility
> https://github.com/busstoptaktik/geodesy/blob/main/ruminations/012-rumination.md
> > [7] Even Rouault om lam0:
> https://github.com/OSGeo/PROJ/pull/4667/changes#diff-bfb0c333155a0c8bf863b0a3e76df46cfddf646cd5f13d6313eb8a3cb123f5f1R58
> > [8] proj_strtod():
> > https://github.com/OSGeo/PROJ/blob/master/src/apps/proj_strtod.cpp
> > [9] Update Rust Float-Parsing Algorithms to use the Eisel-Lemire
> algorithm
> > https://github.com/rust-lang/rust/pull/86761
> > [10] Implementing a Fast, Correct Float Parser
> https://internals.rust-lang.org/t/implementing-a-fast-correct-float-parser/14670
> > [11] David Tolnay's dtoa-benchmark:
> https://github.com/dtolnay/dtoa-benchmark
> > [12] Victor Zverovich's zmij algorithm: https://github.com/vitaut/zmij/
> > [13] OxiGDAL - Pure Rust Geospatial Data Abstraction Library:
> > https://github.com/cool-japan/oxigdal
> > [14] proj4rs - Rust adaptation of PROJ.4:
> https://crates.io/crates/proj4rs
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260312/6f2ef00f/attachment-0001.htm>
More information about the PROJ
