[PROJ] How to not take the direct transformation
Even Rouault
even.rouault at spatialys.com
Thu Mar 19 13:57:00 PDT 2026
No there's no such option but you could easily add one to the coordinate
operation factory context
and when set relax checks about res.empty() likely at
https://github.com/OSGeo/PROJ/blob/8072ad6aae7a11f605c04a7068bd295404705fe0/src/iso19111/operation/coordinateoperationfactory.cpp#L4161
https://github.com/OSGeo/PROJ/blob/8072ad6aae7a11f605c04a7068bd295404705fe0/src/iso19111/operation/coordinateoperationfactory.cpp#L4207
and
https://github.com/OSGeo/PROJ/blob/8072ad6aae7a11f605c04a7068bd295404705fe0/src/iso19111/operation/coordinateoperationfactory.cpp#L4228
Le 19/03/2026 à 21:31, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> There is a "feature" in PROJ that is sometimes inconvenient: if there
> is a direct transformation from A to B, it is not searching for better
> options.
> That can be really annoying in some cases, and confusing as well.
> Is there any way to "disable" it? something in the context? an
> environment variable?
> Example:
> If I transform from WGS84 to NAD83(2011) it is going to use the
> transformation
> https://epsg.org/transformation_9774/NAD83-2011-to-WGS-84-1.html, that
> is a no-op, with 2m accuracy.
> However from WGS84 to NAD83(2011)+NAVD88 it is taking a more
> complicated transformation for the horizontal values. That is very
> confusing. It happens in other situations (that of course I cannot
> remember now).
> I understand that changing the current behaviour could be to big (we
> can discuss if it makes sense or not), but having a way to disable
> that "optimization" would be great.
> Thank you
> Cheers
> Javier.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ
