[PROJ] Synthetic Coordinate System
Ben Griffin
ben at redsnapper.net
Mon Mar 23 13:21:39 PDT 2026
I am honoured to have met both of you, Even, Martin - and I really do value your respective thoughts;
I have invested quite a bit of research time and work I’ve put into this project so far, and your opinions are really valuable.
Martin, your points on ISO 19111/19112 are really well made.
As I understand it - and I am happy to be corrected, it appears that you are confirming that there is not (yet) an
agreed standard as to what a DGGS should be in ISO terms.
However, I feel that ISO 19112 (referencing by identifiers — "what cell am I in?") is a natural home for the DGGS addressing layer: given a location, return an
identifier: That's the H9 address, the H3 index, the S2 cell ID… and it's a different question from "what are the coordinates of this location in the Hex9 projection?”
— which is unambiguously ISO 19111 territory.
My work - Hex9 - straddles both standards cleanly:
- The projection (continuous CRS) — ISO 19111
- The addressing system (H9 cell hierarchy) — ISO 19112
It seems that most DGGS systems have historically conflated these two things.
When I designed Hex9, it became clear that they are better refactored into genuinely separate layers which, while being architecturally unusual, feels arguably correct. (I chose to design the system so that the cell hierarchy is a consumer of the projection rather than intrinsic to it. This, I feel, was a design decision with consequences: Any hierarchical resolution can sit on top of the same CRS without changing the projection.
The PROJ plugin I am currently working on would implement the ISO 19111 layer.
The Python hhg9 package, and/or additional software libraries would implement the ISO 19112 layer on top of it.
Hex9 is truly continuous (although both the python and the PROJ C++ implementation hit machine epsilon limits). The PROJ implementation achieves sub-25nm round-trip geodesic accuracy in current testing — the continuous nature of the CRS is not just theoretical.
There is an additional question worth addressing directly: the CRS is octahedral, and the coordinate geometry is inherently triangular. The hexagonal cell structure arises as a precise consequence of that triangulation — it is not imposed on the projection but derived from it. I will admit that in my own earlier documentation I conflated the projection geometry with the cell addressing, which likely contributed to the DGGS framing. That conflation was mine to make, not the architecture's — and separating them clearly is part of what this PROJ submission is intended to establish.
Kind regards.
-Ben.
More information about the PROJ
