[PROJ] non-continuous integration report for NetBSD 10 amd64: mostly great, 1 test failure
Greg Troxel
gdt at lexort.com
Tue May 19 04:52:33 PDT 2026
I have scripts set up for various projects to build, run tests, and
install to destdir. I haven't built proj in a while but just did for
version:
commit ad36bbd83d79e75632a7d7e52aab397340f5ade9 (HEAD -> master, upstream/master, upstream/HEAD)
Author: Javier Jimenez Shaw <j1 at jimenezshaw.com>
Date: Tue May 19 11:23:36 2026 +0200
(Interestingly, "git describe --tags" gives me a ref based on 9.5.0
instead of 9.8.0, but I don't think that's about proj.)
Things are 99.99% fine.
There are no build warnings.
I got one test failure:
[ RUN ] networking.network_endpoint_api_and_not_reachable_hgridshift
Cannot open http://0.0.0.0/at_bev_AT_GIS_GRID.tif: Failed to connect to 0.0.0.0 port 80 after 0 ms: Could not connect to server
/n0/gdt/SOFTWARE/GEO/PROJ/proj/test/unit/test_network.cpp:1389: Failure
Expected equality of these values:
proj_pj_info(last_op).description
Which is: "MGI to ETRS89 (5)"
"MGI to ETRS89-AUT [2002] (8)"
/n0/gdt/SOFTWARE/GEO/PROJ/proj/test/unit/test_network.cpp:1402: Failure
/n0/gdt/SOFTWARE/GEO/PROJ/proj/test/unit/test_network.cpp:1415: Failure
[ FAILED ] networking.network_endpoint_api_and_not_reachable_hgridshift (25 ms)
I am guessing not connecting is intended given the invalid 0.0.0.0.
(BTW, pkgsrc doctrine is that network use is not allowed during build or
test, but the above build was not in a pkgsrc context other than
dependencines being used that are controlled by pkgsrc.)
The mismatch looks related to ETRS89 realizations, apparently an
Austrian realization vs the ensemble, which evokes MEGA vibes.
I am guessing this is not specific to my system. Are others seeing
this?
More information about the PROJ
