[PROJ] cmake too new in CI
Mike Taves mwtoews at gmail.com
Wed Nov 18 11:48:10 PST 2026
On Thu, 19 Nov 2026, 08:04 Javier Jimenez Shaw via PROJ, <
proj at lists.osgeo.org> wrote:
> On Wed, 18 Nov 2026 at 18:24, Nicklas Larsson via PROJ <
>> The following little patch may turn the error to a warning:
>> --- a/ci/install.sh
>> +++ b/ci/install.sh
>> @@ -44,7 +44,7 @@ if [ "$cmp_44" = "$sorted_44" ]; then  # CMake 4.4 or
>> later
>>  else  # Before CMake 4.4
>>      cmake_diagnostics=dev
>>  fi
>> -CMAKE_OPTIONS="-Werror=${cmake_diagnostics} --log-level=VERBOSE"
>> +CMAKE_OPTIONS="-Werror=${cmake_diagnostics}
>> -Wno-error=non-target-directive --log-level=VERBOSE"
>>   if test "$TRAVIS" != ""; then
>>      # For some odd reason the tar xzvf $TAR_FILENAME doesn't work on
>> Travis-CI …
>> To make the runners pass in waiting for addition of recommended use of
>> target_include_directories
>> Do you think that anybody will implement the recommended usage if it is
> not failing in CI?
Apologies as I was intending to fix this, but am tied up in a conference
week. This is only an error in CI targeted for package authors (us), but
does not normally show as an error for users with the latest CMake.
Cheers, Mike
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20261119/5b0e1a38/attachment.htm>
More information about the PROJ mailing list
