[PROJ] cmake too new in CI
Javier Jimenez Shaw
j1 at jimenezshaw.com
Fri Nov 20 01:44:19 PST 2026
I have the impression that some times the runner has cmake 4.4.5 and others
4.5 (they are deploying the new version gradually).
On Fri, 20 Nov 2026 at 08:47, Nicklas Larsson <n_larsson at yahoo.com> wrote:
> Unfortunately, the Windows CI runner comes currently with CMake 4.4.5, but
> `-Wnon-target-directive` is added with 4.5 [1] so that is not even a
> temporary solution in that case.
> [1] https://cmake.org/cmake/help/latest/release/4.5.html#diagnostics
> On 19 Nov 2026, at 22:25, Nicklas Larsson via PROJ <proj at lists.osgeo.org>
> wrote:
> Missed replying to list, reposting.
> Note the change to `-Werror=author`
> On 19 Nov 2026, at 21:49, Nicklas Larsson <n_larsson at yahoo.com> wrote:
> Javier,
> Try the following patch:
> diff --git a/.github/workflows/windows.yml b/.github/workflows/windows.yml
> index 28683981f..a71f70507 100644
> --- a/.github/workflows/windows.yml
> +++ b/.github/workflows/windows.yml
> @@ -32,7 +32,7 @@ jobs:
> BUILD_SHARED_LIBS: ${{ matrix.BUILD_SHARED_LIBS }}
> BUILD_TYPE: ${{ matrix.BUILD_TYPE }}
> CMAKE_GENERATOR: Ninja
> - CMAKE_OPTIONS: "-Werror=dev --log-level=VERBOSE"
> + CMAKE_OPTIONS: "-Werror=author -Wno-error=non-target-directive
> steps:
> On 19 Nov 2026, at 21:34, Javier Jimenez Shaw <j1 at jimenezshaw.com> wrote:
> Hi Mike
> I tried Nicklas' suggestion in a branch, and got some errors in windows:
> https://github.com/jjimenezshaw/PROJ/actions?query=branch%3Acmake-no-error
> Maybe it is just a coincidence that they are also updating cmake in
> windows now
> (the error in code checks were there before. they are not related)
> On Thu, 19 Nov 2026 at 11:59, Mike Taves <mwtoews at gmail.com> wrote:
> On Thu, 19 Nov 2026 at 08:53, Javier Jimenez Shaw <j1 at jimenezshaw.com>
> wrote:
> What do you mean? I installed cmake 4.5 in a virtual environment in my
> computer (not available yet in pip) and I got a lot of errors.
> Yes, I see lots of errors with a developer-facing configuration:
> ./cmake-4.5.0-linux-x86_64/bin/cmake -Werror=author -S . -B _build
> But no errors with a user-facing configuration:
> ./cmake-4.5.0-linux-x86_64/bin/cmake -S . -B _build
> I like Nicklas's suggestion to consider adding
> -Wno-error=non-target-directive as a workaround while a better
> solution is developed, as it could take a while to resolve.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20261120/426187d2/attachment.htm>
More information about the PROJ
