[PROJ] WKT2 in PostGIS
Javier Jimenez Shaw
j1 at jimenezshaw.com
Wed Sep 9 00:49:05 PDT 2026
Hi
In the new PROJ release 9.9.0 that will be released soon, the latest
version of EPSG is included.
As I already mentioned, all European realizations are included in the WKT2
of any CRS using the ETRS89 datum ensemble.
This is an example of EPSG:25830, with 4264 chars.
https://epsg.org/crs/wkt/id/25830
If you format it a bit nicely it goes up to 4874. And this is just an
example.
I realized today that in PostGIS the table containing the CRS has fields
limited to 2048 chars, in particular "srtext".
https://postgis.net/docs/using_postgis_dbmanagement.html#spatial_ref_sys_table
CREATE TABLE spatial_ref_sys (
srid INTEGER NOT NULL PRIMARY KEY,
auth_name VARCHAR(256),
auth_srid INTEGER,
srtext VARCHAR(2048),
proj4text VARCHAR(2048)
If I have to define a CRS with WKT2 because I need some features only
available in WKT2, it may not work in PostGIS. Am I right?
Anybody from PostGIS team here?
Thank you.
Javier.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260909/fa20d13e/attachment.htm>
More information about the PROJ
