[PROJ] PROJ 9.9.0RC1 and PROJ-data 1.25RC1
Charles Karney karney at alum.mit.edu
Mon Sep 14 04:24:21 PDT 2026
+1 Charles
> On Sep 14, 2026, at 01:13, Kristian Evers via PROJ <proj at lists.osgeo.org> wrote:
> PSC Members,
> No issues has been identified in either release candidate so I hereby motion that they are promoted to the final release.
> I'll start with my +1.
> /Kristian
>> On 8 Sep 2026, at 13.34, Kristian Evers via PROJ <proj at lists.osgeo.org> wrote:
>> All,
>> In preparation for a new round of PROJ and PROJ-data release I have uploaded release candidates for both packages.
>> Download the archives here:
>> https://download.osgeo.org/proj/proj-9.9.0RC1.tar.gz
>> https://download.osgeo.org/proj/proj-9.9.0RC1.zip
>> https://download.osgeo.org/proj/proj-data-1.25RC1.tar.gz
>> https://download.osgeo.org/proj/proj-data-1.25RC1.zip
>> The PROJ release includes both updates and bug fixes. See the release notes below.
>> The PROJ-data release comes with the following additions:
>> * Grids for Greenlandic vertical CRSs GLLAT(2025) and GLMSL(2025)
>> * Norwegian grid for converting ETRS89 ellipsoidal heights to NN2000:2025 heights
>> Please test the release candidates and report any issues you may find with them.
>> Either here on the mailing list or on GitHub.
>> /Kristian
>> # PROJ Release Notes
>> ## 9.9.0
>> ### Updates
>> #### Operations
>> * `tinshift`: support TIN GeoPackage files (#4603)
>> * Optimize `+step +proj=helmert +inv +x=X +y=Y +z=Z +step +proj=helmert +inv +x=-X +y=-Y +z=-Z` as `+proj=noop` (#4775)
>> * Optimization: replace iterative Aitoff inverse with closed-form inverse (#4796)
>> * Adds implementation of Transverse Mercator Zoned Grid System (supporting EPSG:32600 and EPSG:32700) (#4805)
>> * Add seismic bin grid operation methods (EPSG:9666 and EPSG:1049) (#4807)
>> * IVEA: DSEA projection onto icosahedron net (#4817)
>> #### API
>> * Add `proj_create_linear_3D_affine_parametric_conversion()` (#4682)
>> * Optimize `fwd_prepare()` (#4712)
>> * Add support for `DerivedProjectedCRS` registration (#4727)
>> * C++ API: CartesianCS::create(): by default check that all axis have the same unit (#4728)
>> * `createOperations()`: tune `geod_crs_of_datum_ensemble` <--> `geod_crs_of_another_datum` (#4773)
>> * add `proj_crs_is_dynamic()`, and `cs2cs`: warn when source/destination CRS is dynamic, but no epoch is provided (#4792)
>> * `createOperations()`: add heuristics to make BD72 + Ostend height to Amersfoort + NAP height lead to optimal result again (#4821)
>> * Make sure that WKT2 export of CRS imported from PROJ.4 strings or WKT1 is identical (#4844)
>> #### CMake
>> * Only add CPack related options when PROJ is the top level project. (#4722)
>> * Increase CMake minimum version from 3.16 to 3.22.1 (#4824)
>> * Replace PROJ_DATA_PATH with ${CMAKE_INSTALL_DATADIR}/proj (#4843)
>> * Define `target_compile_features` with C/C++ standards (#4847)
>> #### Database
>> * Database: update to EPSG v13.102 (#4829)
>> ### Bug Fixes
>> * Refactor time parsing with thread-safe localtime and leap year fix (#4692)
>> * Make sure `projinfo --crs-extent-use none` works as expected (#4699)
>> * Fix SQLite3 version check so it is done by `find_package` (#4753)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
More information about the PROJ mailing list
