[pycsw-devel] CSW 2.0.2 - APISO 1.0 Implementation
Angelos Tzotsos
gcpp.kalxas at gmail.com
Sat Apr 2 18:55:20 EDT 2011
Hi Tom,
I have added some things in the wiki page.
Also, the iso/inspire xml importer is now completed and commited :)
You can find some metadata in the /data/iso-inspire/iso-inspire.db file.
As you suggested in IRC, I kept the new metadata in a separate file.
Also, I merged the code from trunk with sandbox, to keep sync.
Angelos
On 03/30/2011 11:44 PM, Tom Kralidis wrote:
> Thanks Angelos. FYI we will start to roll this into trunk in the next month or so. I've started a profile dev documentation page at http://sourceforge.net/apps/trac/pycsw/wiki/ProfileSupport to get high level ideas (most of which come from your sandbox).
> ..Tom
> Date: Wed, 30 Mar 2011 04:07:08 +0300
> From: gcpp.kalxas at gmail.com
> To: pycsw-devel at lists.sourceforge.net
> Subject: Re: [pycsw-devel] CSW 2.0.2 - APISO 1.0 Implementation
> Hi,
> Right now the ISO profile is being developed as a plugin.
> It can be enabled by the main configuration file and it also have
> its own configuration file to hold specific information.
> I am trying to insert few lines of code in the core DC model, and
> the profile code will have to implement some specific functions to
> plug in to the core (eg Extended Capabilities).
> There is only one major chunk of code in the core model, which
> involves the get_profile() function. We probably have to move this
> code in the future...
> Also in the sandbox, there is some initial work for INSPIRE.
> Regards,
> Angelos
> On 03/28/2011 04:41 PM, Tom Kralidis wrote:
> .ExternalClass .ecxhmmessage P
> {padding:0px;}
> .ExternalClass body.ecxhmmessage
> {font-size:10pt;font-family:Tahoma;}
> We want to extend the current model by adding the ISO specifics
> via profile. We should also consider the DC model as "default".
> Any profile will have to map back to the core DC model core
> queryables.
> Once the profile is loaded, then the CSW request processing
> continues like any other request. For each profile found, the
> model is extended (probably in CSW init).
> ..Tom
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athens
> http://users.ntua.gr/tzotsos
> Enable your software for Intel(R) Active Management Technology to meet the
> growing manageability and security demands of your customers. Businesses
> are taking advantage of Intel(R) vPro (TM) technology - will your software
> be a part of the solution? Download the Intel(R) Manageability Checker
> today! http://p.sf.net/sfu/intel-dev2devmar
> pycsw-devel mailing list
> https://lists.sourceforge.net/lists/listinfo/pycsw-devel
Angelos Tzotsos
More information about the Pycsw-devel
