[pycsw-devel] AttributeError: 'module' object has no attribute
'get_config'
Tom Kralidis
tomkralidis at hotmail.com
Mon Aug 8 07:39:37 EDT 2011
FYI after some debugging offline, looks like this was a PATH/PYTHONPATH issue.
> From: Nagai.Junichi at imslab.co.jp
> To: pycsw-devel at lists.sourceforge.net
> Date: Mon, 25 Jul 2011 19:25:03 +0900
> Subject: Re: [pycsw-devel] AttributeError: 'module' object has no attribute 'get_config'
> Hi Tom,
> I'm Junichi.
> Thank you for the info.
> > Hi: thanks for the info. Do you have multiple Python installations on your
> > machine? Make sure the Python that PostgreSQL uses for plpython functions
> > is the same used for pycsw itself (and it has lxml installed).
> > ..Tom
> I didn't set "PYTHONPATH".
> I set "PYTHONPATH".
> It disappeared the bellow error.
> > <ows:Exception locator="constraint" exceptionCode="InvalidParameterValue">
> > <ows:ExceptionText>Invalid query: (InternalError) plpython: function
> > "query_spatial" failed
> > DETAIL: <type 'exceptions.ImportError'>: No module named lxml
> > "SELECT records.identifier AS records_identifier, records.typename AS
> > records_typename, records.schema AS records_schema, records.bbox AS
> > records_bbox, records.xml AS records_xml, records.source AS
> > records_source,
> > records.insert_date AS records_insert_date \nFROM records \nWHERE
> > records.typename IN (%(typename_1)s) AND
> > query_spatial(bbox,'POLYGON((-5.00
> > 47.00, -5.00 55.00, 20.00 55.00, 20.00 47.00, -5.00
> > 47.00))','bbox','false')
> > = 'true'" {'typename_1': 'csw:Record'}</ows:ExceptionText>
> > </ows:Exception>
> But, it appeared next error.
> (at (3) I sent "GetRecords-filter-bbox Request" to my pycsw server.)
> DETAIL: <type 'exceptions.ImportError'>: DLL load failed
> records_bbox, records.xml AS records_xml, records.source AS records_source,
> records.typename IN (%(typename_1)s) AND query_spatial(bbox,'POLYGON((-5.00
> 47.00, -5.00 55.00, 20.00 55.00, 20.00 47.00, -5.00 47.00))','bbox','false')
> </ows:Exception>
> Do I need DLL path or anything?
> my environment variable is below.
> path : C:\Python27;
> PYTHONPATH : C:\Python27\Lib\site-packages
> ..Junichi
> > Date: Fri, 22 Jul 2011 12:45:58 +0900
> > Dear Tom Kralidis,
> > I'm Junichi Nagai.
> > Thank you for updating configuration parsing.
> > It works about creating the necessary tables and values for the
> > repository.
> > But I got another problem.
> > (different from [pycsw-devel] About "GetRecords-filter-bbox Request")
> > I imported all *.xml records(pycsw samples) by using
> > "./sbin/load_records.py".
> > (1)
> > I sent "GetRecords-all Request" to my pycsw
> > server(http://localhost/cgi-bin/pycsw/csw.py) at
> > "http://localhost/tester/index.html".
> > I got collect response from my pycsw
> > No problem.
> > (2)
> > I sent "GetRecords-Element Request" to my pycsw server.
> > I got collect response.
> > No problem.
> > (3)
> > I couldn't got collect response.
> > I got below error.
> > records_source,
> > </ows:Exception>
> > I have installed "lxml version 2.3".
> > It works for (1),(2).
> > I think that "FUNCTION_QUERY_SPATIAL" of database don't know where "lxml"
> > is.
> > Could you tell me what's wrong?
> > I use below.
> > pycsw:version1.0.0(http://sourceforge.net/projects/pycsw/files/1.0.0/)
> > OS:Windows XP
> > Python:Version 2.7
> > Database:postgres8.3
> > lxml:version 2.3
> > 10 Tips for Better Web Security
> > Learn 10 ways to better secure your business today. Topics covered
> > include:
> > Web security, SSL, hacker attacks & Denial of Service (DoS), private keys,
> > security Microsoft Exchange, secure Instant Messaging, and much more.
> > http://www.accelacomm.com/jaw/sfnl/114/51426210/
> > pycsw-devel mailing list
> > https://lists.sourceforge.net/lists/listinfo/pycsw-devel
> Storage Efficiency Calculator
> This modeling tool is based on patent-pending intellectual property that
> has been used successfully in hundreds of IBM storage optimization engage-
> ments, worldwide. Store less, Store more with what you own, Move data to
> the right place. Try It Now! http://www.accelacomm.com/jaw/sfnl/114/51427378/
More information about the Pycsw-devel
