[pycsw-devel] Multiple metadata standards -- one "ISO" CSW?
Tom Kralidis
tomkralidis at hotmail.com
Fri Jun 15 12:09:46 PDT 2012
Bruce: if I understand correctly, you'd like to load one pycsw instance with both ISO and CSDGM metadata and serve it out?
Yes, make sure your configuration server.profiles has (at least) apiso,fgdc and then pycsw supports both.
For GetRecords requests, you would then have to specify the typenames parameter with both typenames, i.e. typenames=fgdc:metadata,gmd:MD_Metadata.
Is this what you had in mind?
..Tom
Date: Fri, 15 Jun 2012 11:33:50 -0700
To: pycsw-devel at lists.osgeo.org
Subject: [pycsw-devel] Multiple metadata standards -- one "ISO" CSW?
If I have CSDGM and ISO metadata XML files is there a way to index records built with both standards and present them all as a CSW ISO? Thank you,-Bruce Bruce GodfreyGIS SpecialistLibraryUniversity of Idaho Coeur d’Alene1031 N. Academic WayCoeur d’Alene, Idaho 83814-2277E-mail: bgodfrey at uidaho.eduPhone: (208) 292-1407Fax: (208) 664-1272
pycsw-devel mailing list
http://lists.osgeo.org/mailman/listinfo/pycsw-devel
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20120615/054c9bee/attachment.html>
More information about the pycsw-devel
