[pycsw-devel] Links column from ncISO
dan at inlet.geol.sc.edu
Wed Aug 27 16:41:17 PDT 2014
Added issue: https://github.com/geopython/pycsw/issues/268
> Thanks for the info. Can you point us to a sample record so we can try to
> reproduce / fix? A GitHub issue would be great.
> Sent from my iPhone
>> On Aug 27, 2014, at 15:22, Dan Ramage <dan at inlet.geol.sc.edu> wrote:
>> Now that I have my server sorted out and running properly, I notice the
>> links column is not getting populated.
>> I've run the ncISO command line against a single THREDDS endpoint for
>> testing. I see issue 238 is addressing the issue, however
>> I am wondering if that is in the master branch, I cloned the repository
>> from there.
>> There could be an issue with the ncISO metadata as well, however it
>> looks
>> like the fields are there.
>> Dan
More information about the pycsw-devel
