[pycsw-devel] INSPIRE compliance and PyCSW on Windows
Tom Kralidis tomkralidis at gmail.com
Mon Feb 24 13:36:29 PST 2014
On Mon, Feb 24, 2014 at 7:49 AM, Ramler Georg <Georg.Ramler at noel.gv.at> wrote:
> Hi!
> I´m currently investigating if pycsw can be used to provide EU INSPIRE directive compliant CSW and OpenSearch services (INSPIRE Metadata and Download Service) and wanted to ask if someone already gained experience with that topic or if there are known pitfalls or compliance problems?
> Further I was able to run a setup on Windows with a mysql backend with little tweaking (see github issues) and also was able to setup a Windows Service with Active Python and would be happy to create documentation or a tutorial if there is any interest in the community.
+1!  Docs or tutorial would be more than welcome. What if you add a
section to docs like "Setting up pycsw via Windows Service and Active
Python",in http://pycsw.org/docs/latest/installation.html#running-on-windows
?  Or if it's better in it's own page, then that works as well.
> Also I may be able to attend the http://wiki.osgeo.org/wiki/Vienna_Code_Sprint_2014 and could provide programming and documentation manpower for 2-3 days, to solve pycsw issues regarding INSPIRE, running pycsw on Windows or other topics that helps to get on with the project.
I believe Angelos and Jeff will be there so this would be great to get
some issues worked on like the ones you mention.
All: should we put a project agenda together for the sprint?
> Cheers,
> Georg
More information about the pycsw-devel mailing list
