[pycsw-devel] Records table structure and profiles
Tom Kralidis tomkralidis at gmail.com
Wed Mar 19 16:01:30 PDT 2014
On Wed, Mar 19, 2014 at 11:16 AM, Alejandro Mostovoi
<ahmostovoi at gmail.com> wrote:
> Hi Tom,
>  thanks for answer.
> if I understand correctly, to support ISO 19115-2, I only have to specify
> "profiles=apiso" under [server] section?
Correct.  Outputting elementsetname=full will show the entire
gmi:MI_Metadata document.
>> > Hi all,
>> >   I was wondering if table "records" change its structure based on the
>> > profile selected, and other question is how to configure pycsw to enable
>> > iso
>> > 19115-2 profile?
>> FYI from a CSW perspective AFAIK this is somewhat transparent.  As
>> pycsw stores the entire metadata XML record in the database, and then
>> stores the queryables, any XML record will fit.  We include support
>> for gmi:MI_Metadata.  So, when inserting a 19115-2 document, pycsw
>> will parse and store the queryables and store the original XML
>> document as well (which gets returned when specifying
>> elementsetname=full in GetRecords requests).
>> Does this make sense, or do we need more?
>> Thanks
>> ..Tom
>> > Thanks in advance.
>> > Alejandro
More information about the pycsw-devel mailing list
