[pycsw-devel] PyCSW and SOS
Dan Ramage
dan at inlet.geol.sc.edu
Fri Oct 10 12:03:44 PDT 2014
I'm seeing a "Could not load repository (local)" Exception when trying to
run the SOS tests.
I'm using my production pycsw server, so it does have records in it, is
this an error coming from the SOS server?
Dan
On 10/10/14 12:18 PM, "Tom Kralidis" <tomkralidis at gmail.com> wrote:
>On Fri, 10 Oct 2014, Dan Ramage wrote:
>> Date: Fri, 10 Oct 2014 09:31:46 -0400
>> From: Dan Ramage <dan at inlet.geol.sc.edu>
>> To: "pycsw-devel at lists.osgeo.org" <pycsw-devel at lists.osgeo.org>
>> Subject: [pycsw-devel] PyCSW and SOS
>> Is there a how to link on harvesting from SOS servers? I see pycsw
>>supports
>> it, but I am not seeing the method to do this.
>There are some request examples in the tests:
>https://github.com/geopython/pycsw/blob/master/tests/suites/harvesting/pos
>t/Harvest-sos100.xml
>t/Harvest-sos200.xml
>It would be useful to have some added docs [1]. Any contributions would
>be valued.
>Cheers
>..Tom
>[1] http://docs.pycsw.org/en/latest/transactions.html#harvesting
More information about the pycsw-devel
