[pycsw-devel] GetRecords question
Tom Kralidis
tomkralidis at gmail.com
Thu May 7 13:28:03 PDT 2015
Hi Alejandro: to return all the bounding boxes in a GetRecords
response, set ElementSetName=full which will return the full ISO
record.
If you mean spatial querying against all bounding boxes, pycsw (using
OWSLib) uses the first bounding box found to apply the wkt_geometry
value for the record. We *could* extend the ISO parsing/handling to
aggregate the various bounding boxes as an enhancement to the
codebase.
On Thu, May 7, 2015 at 4:07 PM, Alejandro Mostovoi <ahmostovoi at gmail.com> wrote:
> Hi All!
> I'm using pycsw 1.10.1.
> I've catalogued some geographic dataset that have several bounding box,
> using Metadata Profile ISO 19115.
> When I execute the GetRecords operation It only returns the first bounding
> box of all existents.
> I looked into the records table and the wkt_geometry column only have the
> first bounding box of the metadata, which is returned.
> It's posible to get the others bounding box? And If It is, How?
> Thanks in advance.
> Alejandro
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel
