[pycsw-devel] revamped CLI for pycsw-admin.py
Tom Kralidis tomkralidis at gmail.com
Sun Apr 24 08:25:40 PDT 2016
Ricardo: thanks for the info.  Looks like we can leverage these
efforts!  I think an RFC would be valuable in moving this work
forward.
On Sat, Apr 23, 2016 at 6:59 PM, Ricardo Filipe Soares Garcia da
<ricardo.garcia.silva at gmail.com> wrote:
> +1 from me.
> I had actually started doing something very similar to Tom's proposal last
> year[1].
> I never got around to finishing it because I got carried away and started
> changing other things which didn't get finished ;)
> What I had done:
> * replaced optparse with argparse
> * use argparse subparsers
> * decided on which parameters were optional and which ones were mandatory
> Something which was on my mind as well was investigating if/how this newer
> implementation could be integrated into other tools, for example django's
> django-admin.py.
> If folks are positive towards this change, It might be worth it to salvage
> my previous work and finish/improve it.
> [1] -
> https://github.com/ricardogsilva/pycsw/blob/refactor_admin/bin/pycsw-admin.py
> On Sat, Apr 23, 2016 at 11:20 PM, Tom Kralidis <tomkralidis at gmail.com>
> wrote:
>> Hi all: given we are headed towards 2.0 it's a good time to think about
>> serious changes that would valuable.
>> One that has come to my mind is revamping the CLI for pycsw-admin.py
>> to be more elegant, in particular:
>> 1./ using subcommands
>> Instead of:
>> pycsw-admin.py -c post_xml -u http://localhost:8000 -x path/to/file.xml
>> pycsw-admin.py post-xml http://localhost:8000 path/to/file.xml
>> Figuring out what's a positional arg (beyond the first 'subcommand'
>> are) and what's worth a flag will need investigation.
>> 2./ moving pycsw-admin.py into into pycsw.core.admin within __main__
>> and declaring pycsw-admin.py as an entry point in setup.py.  Looks
>> like this requires a move (from distutils) to setuptools
>> Thoughts?  What approaches
>> or tools/libs can we use to move this forward?
>> What do folks think about renewing the CLI?  Is it worth it?  Too much
>> trouble for something that 'works'?  Of course this would
>> break the existing CLI, but if folks agree this is a good idea, now
>> is the time to move this forward.
>> Cheers
>> ..Tom
>> pycsw-devel mailing list
>> pycsw-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
> ___________________________ ___ __
> Ricardo Garcia Silva
More information about the pycsw-devel mailing list
