[pycsw-devel] PYCSW Win10 Install Issue
Tim Wanner
tim_wanner at web.de
Fri Sep 21 06:23:58 PDT 2018
Hello Mailing-List Members,
I got issues installing PYCSW on Windows which I hope someone can solve.
I already tried I a lot and read many forum contributions as I’m not professional in programming and installing trough a terminal/shell but I just could not fix this.
Trying to install as shown on the website (changed csw.py 1.Line to #!/Python27/python). I’ve installed Python 2.7.14 aswell as 3.5.x.
After I fixed Issues with missing Visual C++ 14 Compiler Build Tools (for pyproj Installation needed) aswell as issues with Shapley(1.5.17) which I installed separately and put in the LIB folder so that works fine now.
I run into this Error and could not find an answer in a working solution in the web?
OUTPUT FROM THE CMD:
https://gist.github.com/TimWanner/4e2a6c3d42d4d68b28c4376018ab31a4 <https://gist.github.com/TimWanner/4e2a6c3d42d4d68b28c4376018ab31a4>
I’d Appreciate it if someone can help me out!
Do I need to install extra Microsoft Visual Studio’s parts, and if so, which one exactly should that be ? // Anything else needed pre installed to get it running ?
Best Regards
Tim from Stuttgart
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20180921/35d57dec/attachment.html>
More information about the pycsw-devel
